Riptide 80 co-pilot speed control failure
Zoobs
speed control has failed. What parts do I need to repair this and where are they available? Also, I have a bit more wobble in the shaft at medium and high speeds than when the unit was new. What parts do I need to repair this as well?
Thanks, Stu
Camdenites
Re: Riptide 80 co-pilot speed control failure
Pertaining to the speed control.....
All you'll need is a #2 phillips screwdriver to get to the switch. There is a pressure activated sealed switch inside. Very easy to get to....
