Riser Gasket Compound or Not?
thetrub
I am installing a new exhaust manifold gasket and it says not to use gasket sealing compound on it. I'm also changing the riser gasket. Does anyone know if I should use sealing compound on that or not? Thanks :cool:
sundowner205
Re: Riser Gasket Compound or Not?
What is your specific setup and application? We need that before we can help. :)
Ayuh,....
Mercruiser gaskets go on Dry....
If they're GLM manifolds,....
You can't get enough Glue on them to stop them from Leaking....
I had to have mine Machined Flat.....
thetrub
Its a Johnson/Evinrude Gasket on a 2.3L Ford/Omc Capri Bayliner. How do you check if the riser is flat? Thanks.:D
chiefalen
Run a metal square on them. If not square and true, use a file.
Than you could use Permatex aviation form a gasket, i know it won't melt.
Do you know how to pray. If yes?
Then pray that the fix works, and someone buys that boat from you ,right after you fixed it.
