riser gaskets questions
reefguy
hello,
I have a '79 sea ray weekender 260/350, i just got thru taking off the riser/cracked from the log style manifold. I am having alot of problems locating the serial numbers for the motor, so i can order the right gaskets. The questions is manifold has 3 open slots and middle hole and so does the riser, but there was 2 gaskets and metal gasket with not slots that was taken off, should there be the metal gasket without the slots blocking water to pass thru, pretty causing to corrode since water is able to pass thru? any info. would be greatly appreciated.
anthony
reefguy
Re: riser gaskets questions
and what is the normal riser gasket configurations, is the metal gasket sandwich between the thick paper type?
Bt Doctur
reefguy
is the gaskets the same for the log style manifold? because thats one that i have..
