Hello All,
I just started my boat for the first time this year. Its a '99 4.3L with Alpha 1 Gen 2 (0L323711). Good news is it fired right up without much fuss. Ran smooth and everything else checked out. My only concern is after about 15-20 minutes running all under 1500rpm, the port riser became hot, couldn't keep hand on for more then couple seconds as well as the rubber boot started feeling real soft. I shut down and let the hose run a few more minutes. The line leading to the riser was cold, the starboard riser stayed normal maybe little cooler. I opened the drain on the port riser after shut down and with hose running and water flowed from it. The boat was on a angle during (starboard was low side) this as indicated by the pictures. Does this have as large effect as I think on how the manifolds cool. I'm going to try and run it again tomorrow and try to be more level as well as buy a laser thermometer. There were no problems before it got winterized.
I also could not get temps above 130-135ish. I know this could be because hose water was still pretty cold and as I said rpms stayed below 1500 but not sure if it should have gotten higher. I got the boat end of last season and ran it once to test it all, temp never got above 140ish but that was in 40-50? water so I assumed that's why.
Thanks in advance
Thanks in advance
