boatingfool
- Joined
- Nov 30, 2002
- 610
What do I have in there? Raw water passing through or the mix?<br />I have followed the raw water tubes and one tube comes into the top of the heat exchanger and then another tube also comes out the top and the tube follows the riser (runs underneath it) back to the transom. then the riser and tube come together where they enter the out drive.<br /><br />I cant see how the raw water would get into the riser ??<br />But I was tinkering with the boat the other day and ran my finger across the riser drain and it had clear water drop(no green at all) with a little rust in it formed up on the bottom of the drain.<br /><br />So whats in there??
