I thought I read a post on flotation regarding foam panels but can't seem to find it now. All I'm looking to find out is how many pounds of boat (out of water) will one cubic foot of pink insulation board float when submerged. Boat had styrofoam from factory (1961 Crestliner) which lasted 40 years so same is going back in. Before you say so I'd use foam but to do so I'd have to go through all the BS of glassing the floor to the hull and such. Right now it's just plywood with i/o carpet screwed to ribs. Foam will be next year when I do a proper retrofit on this boat. I thought I read 100lbs. boat =1 cubic ft. styrofoam. I'm a carpenter and have tons of free closed cell o/c panel material.I guesstimate that the boat motor and gear weigh in approx. at 1300lbs. Any help would as always be very much appreciated. An answer will be welcomed along with the appropriate amount of flack for asking another flotation question. At least I'm not using ping pong balls.
