Re: rochester 2-bbl carb flood
sounds like you need to get a rebuilt kit and a new float! you can get a kit that comes with all new gaskets and needle and seat, if you look on the side of the carb there should be a set of numbers in the vertical position, copy all those down and go to your local parts house and ask for a carb rebuild kit and a new float, they will know what to do from there, when you take carb apart to do rebuild it just spray the heck out of it with carburator cleaner and make sure all the passages are clear, the carb kit will have a sheet that shows how it all goes back together. just follow the directions and you should be fine!! Good luck
