redgoat
- Joined
- May 23, 2010
- 102
I have a '67 SeaRay with a mercruiser 120 IO 4cyl engine. I am rebuilding the carb. There are two small balls in the rebuild kit. I know one (the larger steel ball) goes Under the "T" and is held by a long spring. Does the other smaller ball get dropped into the accelerator pump well OR does this carb even use the smaller ball. I did not find one when I disassembled the carb. However, they may be one in the bottom trough that is stuck at the outer edge and barely visable. Please advise.
