Re: rochester carb refurbishers on e-bay
Paul,<br /><br />Edelbrock makes a 750cfm marine, squarebore, the #1410. They are less than $300 each at Jeg's and other sources. About the lowest cost marine carb you are going to get, new. Not sure if it would be close enough tuning out of the box, but you will probably want the tuning kit. They run about $50 each. Fuel line changes from qjet to weber/edelbrock. Flame arrestor should fit. You may have to change intake manifolds or use the dreaded squarebore to qjet adapters. This would probably raise the height, about an inch. Check to see if you have enough space. Might be a few other minor items. I am not that familiar with BBs.
