I'm starting to think that I inherited the boat of Frankenstein! My latest issue is with the carburetor, The boat is a 1979 SRV240. The engine is a 5.7L MerCruiser. The PO put a new Rochester Quadrajet on the boat. The first issue I came across was he used and apparently reused the gaskets several times, he also had two gaskets on top of each other that were not the same and actually one of them created a space causing a intake leak he decided was best fixed with some kind of rubber cement. Easy fix one new gasket....the next issue is with the choke. I noticed that the choke lever on the carb was just flapping in the breeze, not attached to anything. I can see where a divorce choke of some sort was maybe used in the past (unused holes in the intake for screws) but no signs of it now. I assume my options are divorce choke kit, or a electric choke. I'm I on the right track? Which fix is better?
Thanks
Gerry
Thanks
Gerry
