Rocker Arms configuring for 1987 mercruiser 165 4cylinder 3.7 L engine
broush69
I took out the carburator, Air manifold, Exaust Manifold, expansion tank for anti-freeze with care. Then with a 1inch wrench i removed the bolts from the head and managed to get the head out. Once the head was out I used a Punch tool and hammer and hammered the ezout after about 4 wacks. Once that was out i got a torch and torched up the threads of the spark plug still stuck in the head for about a good 2 minutes. and used an ezout and removed the threaded part of the plug out saving the threads on the head!! =)
However once i put in all the parts back in i couldnt get the engine to turn!! All i did was set the rocker arms to 20 pds/ft with a tourque wrench. I was wondering how to set the rocker heads(still an amatuer when it comes to engines) its a 1987 mercruiser 165 3.7L 4 cylinder 2 bbl engine. if anyone knows how to set the rocker arms and can give me some easy instructions it would be helpful!!
fmalott
Re: Rocker Arms configuring for 1987 mercruiser 165 4cylinder 3.7 L engine
don't try to turn over again your going bend the push rods if you haven't already use the manual that Eric supplied it tells you how to do it very easy to do GOOD LUCK !
broush69
Ya i was worried about it not being right i turned the key over 3 times and only heard a clicking noise coming from the starter. I hope i didnt ruin the heads. and thanks guys for the information. greatly appreciated!! :D
fmalott
loosen all the rocker arm nuts and start from the beginning with the manual beside you hopefully there is no damage
Don S
Did you get all the pushrods in the same exact location as they came out of?
broush69
ya all are on the same spots they were taking out of. and ya i'm going to reset everything and start from scratch today! Thanks guys wish me luck.
