Rocker Trailer Jack
Jeep Man
Re: Rocker Trailer Jack
DEFINITELY. I saw a guy use one at a rest stop and thought it was the best thing since zippers. Almost makes you wish you had a flat tire. Yeah...I bought one.
golf101
Excellent. I just bought one online. I hate messing with jacks. Hope this is easier and more convenient.
dodgeramsst2003
So I looked at the picture, and it appears this is only going to work with a tandem axle trailer? i've also seen something similiar that works on the axle itself.
golf101
You're right that this will only work with tandem axle trailers. I think the one that works on the axle is only for a single axle trailer.
clarkbre
At the expense of sounding stupid, what happens if your tow vehicle gets a flat? :D
With all of my trailers, I always carry the correct lug wrench and that's it. My tow vehicle is always equipped with it's own jack. I figure if it will lift my vehicle, it will lift the trailer as well. There's no need to spend the extra $ and carry an extra tool that you already have onboard.
tashasdaddy
clarkbre . your thinking not correct for all vehicles, a trailer you jack up the axle, some auto jacks do not lend themselves to that task.
the above item is good as long as you are on a firm surface, dirt road, on the shoulder of the road, you would be out of luck.
golf101
I've got a scissor jack in my tow vehicle, but, for $45 bucks (from a vendor other than Cabela's), this drive on jack seems like a lot easier way to get a tire on and off. Moreover, with a flat on the road and 3 kids and a wife in the truck, the faster and easier it is to get the flat off and spare on, the better. Doesn't look like it will take up much room, and I will probably store it in a locker on my boat. (Of course, it could also be that I just feel the need to buy a new toy, and I'm doing my best to justify the purchase).
golf101
Billdc. I'm with you on that. Don't think I could get comfortable using it (although it does get good reviews on the sites that sell it).
golf101
Chalk this one up to the: "It seemed like a good idea at the time category." Althought easy to use, I have 14" tires, and the EZ Jack did not jack up the trailer high enough to put the spare on. I had to use a bottle jack to get the tire back on (which is the jack I will use from now on).
Provo5
I have seen a lot of bent axles come through my shop because of this type of jack. Axles tubes have never been designed to be a lifting point. Spring pads or trailer frame only.
golf101
Which jack: the bottle jack or the EZ Jack? Thanks.
eli_lilly
The single axle one came with my boat and I'd never use it, it sits in the back yard by the gate. It feels like it weighs about a pound and every time I walk past it I imagine the aluminum collapsing and sending the boat trailer down towards me as I change the tire. A single use bottle jack costs about as much as a soda at the local china-direct (walmart or harbor freight). Or at least more than my insurance copay.
-E
