ct1762@gmail.com
Ensign
- Joined
- Jan 17, 2019
- 933
I've been pondering this question for a while and thought i'd see if anyone has thoughts on my little theory regarding connecting rod caps on 2 stroke outboards. I only rebuild OMC motors, and use the rod cap alignment tool when needed (NOT on the hand-sanded rods, of course), but this applies to any cracked rod, i suppose. My observations lead me to believe a large number of these rods have a seam or seams that can be just felt INSIDE the rod from the factory, as they are easy to get perfectly matched on the outside, but not always so on the inside. the manual just seems concerned with ligning up the outsides, and thus leads me to believe a small seam on the inside isnt a problem. Do you think the engines actually seat themselves after some running? after all, there are tens of thousands of PSI on the caps when running, and are only held toghether with 30 ft/lbs of torque. The bearing cages seem to provide some protection.I've put many motors toghether when feeling a tiny seam on the inside, but nothing on the outside and they are still running fine. with a stethoscope, i can never hear any weird noises when turning them over. what's the verdict here? getting brand new rods for each rebuild just isnt practical or affordable, either.
