G'day mate. I noticed that you posted a reply to a 70hp stalling problem and said that to drain the carb bowels you take to the 10mm brass hex bolt with a slot for a screw driver. Is that the same as my Yammy 93 115? Is the process to remove those and then using the primer bulb squeeze through fresh fuel to flush them out?<br /><br />Cheers mate.
