Re: Rodbolt or anyone else??
Thanks rodbolt. I am leaning toward the 200. The boat is a little nicer and it will be much better on fuel. When I found out the warranty was only 4 months on the 250 and then looked at the performance numbers my opinion changed a little. I agree about the preventive maint. I am a stickler for that as well. I have read tons of threads on several forums about the o2 sensore, VST screens, vapor separator screens, fuel pumps/injectors. I guess if an engine seatrials good and the previous owner has good maint record (and used Yamalube & Ringfree), there is not much left to do unless you have a good Yamaha guy close by that can give you an inspection on short notice.<br /><br />On another note, they have been tearing up the YFT this fall in your area. I plan on being there alot starting next March. I may store my boat in Manteo during peak season to eliminate so much towing. If I am ever in need of a good mechanic in that area, I sure would like to be able to leave it with you. I'll bet you stay so booked up you never have room for new customers. If you don't mind, send me your contact info. My e-mail is in my first post.<br /><br />Thanks alot,<br />Alan
