Rodbolt - Thanks for the detailed 150 2-stroke carb rebuild procedure
Status
Not open for further replies.
Osprey
Rodbolt,<br /><br />Thanks for posting the following detailed carb rebuild procedure for 2-Stroke Yamaha 150 motors. I have a 175, but this looks to be about everything I would need as well. <br /><br />Anyone with a V6 Yamaha 2-stroke and thinks they may do a carb rebuild in the future should copy paste this one to a file and save for future reference. You could save a couple hundred easy $.<br /><br />Rodbolts original post:<br /><br />if you have never done yamaha carbs you will need two voodoo priests, a witch doctor, a shaman and maybe a buddist monk.<br />naaaa just kidding. <br />leave the monk alone.<br /><br />that motor has three two barrel carbs. each barrel feeds a cylinder. take careful notes when dissasembling. I usually back off the idle speed screw 3 turns before removing. then remove the carbs. its best to push the hoses off the bowl inlets rather than pull. sometimes I work a thin small screwdriver blade under the rubber to help break it free. when you get all three on the bench make careful notes as to the size of the mainjets in each bowl. sometimes they are odd sizes and if they are they must go back in the same location. now we remove all the fuel bowls. remove the main jets(12mmhex) carb drains(10MMhex) and the idle fuel jet plugs ( small brass slotted screw).<br />dont lose the metal washers under the idle fuel plugs, they dont come in the rebuild kit, however spare fuel bowl screws may . I dont try to remove the idle fuel jets unless I have to. they are small and easy to break/destroy. soak the bowls in some carb cleaner. remove the orings from the main jets and soak them to. on to the carb body. remove the floats use a piece of cardboard to lay them on in order. helps on reassembly, usually if the same float goes back in the same spot you wont have to adjust them. float height is measured with the bowl gasket in place carb upside down and from the gasket to the top of the float. .630" plus or minus.02". on the body. I remove the two small brass slotted pugs inside the throat. I usually dont remove the idle air jets. the two small jets at the upper outer edge of the throats. remove the idle fuel screws and the stainless plate. I usually dont remove the two large brass plugs at the top rear of the carb unless its been under water. I have seen many break the casting when removed after so long.now soak the bodies for 20 min or so. remove all parts and wash with water. blow out with air. then blow out with spray carb cleaner, the super tech brand works good. now blow out with air again. reassemble with new gaskets and needles. set mixture screws at 1 1/4 turns out. install the carbs. install the throttle links. loosen the carb sync screws. they are left hand thread but if you look they are marked.while holding the bottom shutter closed tignten the synch screw then do the top. I dont know which oil pump you have. follow the procedure in your manual to insure its set correctly. some of the old kien pumps set at WOT and the mikunis with the pump arm closed and the throttles fully closed. now turn the idle screw back in 3 turns exactly. now set the throttle roller inline with the mark on the cam ( sometimes the cam must be disconnected to perform the first 3 steps) now make sure all cam,throttle,choke and OIL. repeat OIL links are installed. prime the system and fire it up.<br />its imperative to identify and properly check/adjust the oil pump. the 88 originally had a pump with 6 nipples in a circle pointing up (kien). the conversion pump has 6 nipples 3 pointing fwd and 3 pointing aft (mikuni). I think the two set up differently but memory is muddy.follow the manualif any steps are different from above. like I say memory gets muddy. but thats about the low down and skinny of it.
rodbolt
Re: Rodbolt - Thanks for the detailed 150 2-stroke carb rebuild procedure
osprey<br /> the procedure will cover most v4 and 90* v6 2.6l motors. its useful most times. if the motor was submerged then the procedure is slightly different. mostcarb issues come from congealed fuel in the bowls. the air bleeds and the idle air passages hold no fuel. the twolarge brass plugs at the top rear of the carb are there becuase the passages had to be machined then capped off. the casting is rather thin and older saltwater motors have tendancy to split at the thread line on removal. so most times I blow carb cleaner through the passage and watch the spray pattern from the idle feed holes in the carb throat. there are many tricks and shortcuts that can be safely taken. rare occasions I have to take them back apart for a complete disasembly but its very rare. one marina I contracted for for 5 years had about 450 boats and I was the only tech. time was rather limited. I also do contract work for 3 to 4 other marinas and still do my own mobile service. the past 6 years have been rather busy :) :) . but I have done this type work for about 30 years soby careful observation,training and reading how things work I have developed ways to do things and stay inside the service manual procedures. so always read the procedure, understand what is to be done and why. pay attention to the little things and have fun :)
tperk100
Is this 15 yr old thread still alive? I need more info on this subject.
Fun Times
Sorry tperk100 but iboats preferred preferences towards threads (especially technical threads) are of that no threads are to be considered alive/active after 90 days of inactivity and best left as an archive and to create a new thread of one's own that is unless the thread in question is of your own...Also if felt needed some may link these types of threads over into their newly crated threads for a more helpful reference point of understandings of your situation.
Older threads such as these become closed for comments as they popup like this.
Also unfortunately iboats hasn't seen the seen the presence of rodbolt in many years now.
We wish you good luck with getting your boats situation all figured out.
iboats Mod Team
Status
