Gentlmen would someone explain the roll and tip method with regards to painting. I understand everything right up to the point where you use a dry brush or dry roller to smooth out the first coat application. So now you have rolled the first coat on a 4'x4' area (for argument sake),you use a dry brush or roller whatever, everything looks okay, you proceed to do another 4'x4' area usingf the same roller,now my question is the 1st. brush and/or roller have some paint on them,do you "chuck" those and use some new ones or do just carefully wipe the paint off them and then keep on using them.If thats the case could you get away with using your first or primary roller and your "tipping brush or roller" if you're painting an 18' boat.
Bailey
Bailey
