Re: Rookie Dual Battery Question
Old C -- If that scenario happened like you said, (the alternator quit), and the switch was is BOTH, It was the fault of the operator, not the switch. Alternators fail. The voltmeter should have told him/her that. At that point you immediately go to "power conserve" mode by switching to one battery or the other and turning off all unecessary electrics. With all the electrics on a bigger boat it does not take long to drain two batteries -- especially if one is weaker than the other. You implied it was the switches fault. I need to disagree with the BOTH setting causing alternator damage. If the battery switch is properly wired and with BOTH selected, the alternator does not know and could care less if its output is going to one battery or two. Why? -- because electrically, two batteries in parallel is simply one bigger battery to the alternator. In comparison, its like having a motorcycle battery in the system or an automotive starting battery. The alternator doesn't care. As I pointed out earlier, if one of the two batteries is bad (such as a bad cell or internal short), yes, charging problems could arise, but that can happen if you don't even have a battery switch. Or how about the operator that thinks, my BAT #1 is low I better switch to it for the run back to port. That battery is bad so an alternator could very likely hatch. It simply makes no difference what setting is used if there is an electrical problem on the vessel. Besides, an alternator failure can occur and suck a battery dry in short and it does not have to be the fault of the battery (or batteries). If the BOTH position was a problem, switch manufacturers would not be permitted to have the provision for safety reasons. It simply amazes me how little people know about the vessels and features they stake their lives on when going on the water. Especially offshore.
