bryonthefly
- Joined
- Mar 30, 2009
- 60
First of all I would like to say hello to eveyone, you have a great site here. I traded in my good ol '87 Basstracker for an '08 Lowe FM165 with a 75hp Mercury Optimax last fall and really didnt have much time to dial in a prop set-up. Im running a Blackmax 13 by 19 prop now that gives pretty good performance. Good holeshot, 40.2 mph on GPS but blows out a little in the corners. I can trim down a little to eliminate the loosness in the corners so Im really not to concerned about that aspect. My concern is WOT rpms, only showing 5200-5300 on tach. I ran the numbers through Mercurys slip calculator and Im only showing 2-3% slip. Is this even possible? Im suspecting that my tach may be off a bit?? How do you make sure your tach is not lying? The numbers: 19p prop, 2.33 gear set, 5300 RPM, 40 MPH equals 2% slip. Thanks!
