Rotary? Steering - Older Outboard
atengnr
Ive got an older boat with a recently installed 1998 Johnson 60 and rotary (not sure of the correct name) steering. Im beginning to think Id rather go back to a motor that is more the vintage of the boat. Can I make a 1968 Johnson 55 connect to the push-pull?
Thanks.
JB
Re: Push-Pull Steering - Older Outboard
I don't think push-pull ("stick") steering is a good idea with engines over about 40HP, but, yes, I think you can hook up a 1968 55HP Johnny to it.
atengnr
Sorry, im probably using the wrong terminology for this steering. Whats it called? Its just the standard steering for this motor (1988 60hp Johnson).
vandy21
when you say push-pull steering what do you mean? Do you mean that system with a pulley type thing in which you rotate forwards and backwards to go left and right? Thats what I think it means, but i may be wrong, (I'm not and expert). Or do you mean tiller steering? Or something else I've never even heard of? haha
atengnr
I believe its called rotary steering. Yes, where the linkage moves left and right at the motor (shorter and longer).
tashasdaddy
does it have a steering wheel and a single cable that runs to the motor. or steering wheel with cables and pulleys. or does it have a stick like that you move to turn the wheel.top is cable pulley, 2nd stick steering, 3rd is rotary, 4 is rack.
atengnr
It has a steering wheel and a single thick cable connecting to the motor. Based on the pictures its either rotary or rack, and I believe its rotary given that the unit under the steering wheel is a cylindrical shaped unit.
sdunt
Re: Rotary? Steering - Older Outboard
The older OB were designed for cable and pulley steering systems, but there are a number of options to adapt them to "teleflex" single - push pull cable systems.
One manufacturer of such mounting systems is T&R marine: http://www.trmarine.com/cats/mounts.html
You might want to read my Blog about what I had to do to adapt a 1965 OB to push-pull steering.. http://www.shareaproject.com/pages/projectTut,p,205,00.html
Keep in touch, this is not something lots of people have done.
