mr gibbs2
- Joined
- Aug 20, 2004
- 121
I was going to caulk under acess plates and when i took it apart , not good the area is bumped out underneath about 1 foot by 18 in and stops on all 4 sides . I've cleaned out almost all that is damaged and cleaned it with actone and will rough it up wit sand paper . Any recommendations on what to do do next I can definitely get it dry and inject epoxy in it . I was thinking west system s10 cartridge and fill it up ,and use the penetrating epoxy in the end of the core that is left ,or domed it have to be cut out and done over . I doint know it it is going to work . I think it was cored to mount the acess plates and wireing tube . Dosent seem to be andy wood in the transom someone driled a hole for a transducer cable under the water line , I'm fixing that but no wood in the layers ,and I called the manufacturer , any way I hope not. Help I sold my other boat and picked this up maybe I should give up boating
