rotten transom
74Baja
I have an old boat ('74 Baja 16 footer outboard). I've heard several horror stories about rotten transoms. I was wondering how I would know if it's going bad. Thanks. :cool:
05GlastronSX
Re: rotten transom
pull up on the motor in an up and down motion and see if the transom flexs at all. if so you probably have a rotten or rotting transom
red10
Re: rotten transom
one way is to stand on the anti ventilation plate and bounce a little, have somebody watch from the side and see if it flexes.
txswinner
Banned
Re: rotten transom
Also if you can stick your finger thru it, it is probably rotten.
woosterken
Re: rotten transom
74 Baja,if you find that your is bad go to <br />shareaproject.com there you will find directions and pictures on how to repair it.<br />hope this helps Ken
craze1cars
Re: rotten transom
From the inside, drill a hole part way into the wood low on the transom. If the wood comes out wet/rotton, you have a problem brewing. If the wood drills out clean and dry, seal the hole up solid with resin and thank your lucky stars. Be careful you don't drill too deep unless you want to install another drain plug!
