I was in the process of switching my engines on my '62 Larson Tri-Hull 16.5ft. The plywood in between the sheets of fiberglass is rotted out. What should I do? The boat is a two-piece so I might have to use a dremel and cut it in half again and replace the wood. Would it be safe to use a 30hp Johnson on it or would it rip the transom off?
