fishfeatures
- Joined
- Mar 29, 2011
- 743
hi
89 johnson 60hp
I have attached a new power head and am just fine tuning it out. I have it idling at 800 in the water and about 1200 on the muffs. I notice though it's running slightly rough.
Compression is within specs and i have good spark and the timing has been done with a light and that is within spec too. However when running if i remove #1 plug lead the motor will start to die #2 nothing really happens when lead removed and #3 will make the engine start to splutter and die a few seconds longer than #1 results.
Now as I said I have good spark going to #2, I even changed out the coil (but knew this wasn't the issue), changed leads from #1 to #2 and vice versa and still same result. Even changed around the spark plugs and the result was the same.
I'm thinking that if i pull each lead off the reult should be the same no matter what cylinder ..yes?? also aren't these 3 cyl loopers good to run on 2 cyl? I'm thinking of borrowing another comp gauge as this is the only reason i think the engine dies when #1 or #3 is removed. I don't think all 3 cyl are good.... oh also new head gasket went on to the motor and all bolts torqued and rechecked while i was running my water tests.
Any ideas or am I just over thinking this? I haven't had it out for a proper spin yet as I am waiting for it to be spot on before I UNLEASH my new motor on the bay...
89 johnson 60hp
