rough idle? Check your grounds
gradytom
Had been having trouble holding idle, had run out of ideas and decided
to look everything over again starting with finding every ground wire on every component.
Finally did find a loose ground, from the starter solodoid to the block.
Was barely loose, would not have found it visually. Tightened her down and the idle issue went away.
Check your grounds, sometimes its the simplest stuff.
