Hey all, I have a 1985 johnson 60hp, 2 cyl. I have rewired it, new coils, new plugs, new fuel lines, cleaned carbs 3x completely with replacement parts, new control cables, new filters, and fresh gas. It starts fine, runs great, but when it is at idle the motor is not as smooth as it should be (dances and twitches). I thought it was the idle jets but they are clean as can be, thought it was the primer solenoid that was left in the bypass mode, but nothing I can think of solves the problem. Don't think it is the carb as they only have high/low jets with no adjustments, and have sprayed exterior of carbs with cleaner while running and no vac leaks, throttle butterflys are not sloppy and synced...I'm running out of theories... Anyone have any ideas??? Thanks Bruce
