I have a neighbor friend with a late 80's Searay with a 4 cyl Merc. Not sure of the exact model.
It starts just fine but has a variable rough running condition that seems to get more pronounced once the motor has warmed up. It's using stock points, properly gapped and the timing is right on. It about acts like bad gas, but it isn't.
Here is the kicker. You turn on the depth finder and it goes from mild/variable to significant/constant. Turn off the depth finder and it returns to a mild/variable raggedness.
The depth finder is wired direct to the battery (+ and -) and cannot create much of an electrical load anyway. But this condition is undoubtedly caused by an electical issue.
I am not familiar with this Merc setup so I was wondering if there is some component or ground condition that are/is the likely culprit.
