Plankwalker
- Joined
- Sep 28, 2020
- 79
The carb was just fully serviced and the water impeller replaced. Gas tank was cleaned and fuel line replaced. Filter was rinsed with solvent. It starts fine and after a bit of warm-up, I adjust the high-speed needle and the engine is running fine at top speed. Then, after only a few minutes, the RPM drop. Further adjustment of the high speed needle do nothing. The engine will continue to run without problem, just with lower RPM. I check the vent and it is fully open.
I am suspecting it is the float that needs adjustment to allow for more fuel in the bowl.
Any ideas?
Any ideas?
