Hey guys,
I have a 198dlx Carolina Skiff with the 115 yamaha 4 stroke. I have been running a 3 blade Solas 13 1/4x17P prop for a couple years and have started getting into watersports and I purchased a 4 blade Solas amita4 13x15p prop. The break down is this my 3 blade gets 41 mph by GPS at 6000 rpms(perfect rpm range for my motor,6000 max.) My amita4 is hitting my limiter which is bad but my hole shot and turning are awesome, so 6200 at 33-34 mph so quite a bit slower. One thing I will add is I was getting tons of ventilation out on my 3 blade which made me want to go with a 4 blade even more and when I got my 4 blade I was getting venting also mainly on turns. I lower my motor one bolt hole and it has corrected all my venting on turns and taking off with both of my props they bite a lot harder in the turns now especially with that 4 blade.
My question is I am wanting to purchase the Solas Titan4 in a 17p and I am reading where the Titan series have more cup,rake and the blades may be more aggresive.
Final thought, the amita4 is a great prop night and day faster on hole shot than my 17p prop which is what I want but at the same time I would like to keep my rpms under my 6000 mark or a little over(I can always pull back a hair.) So if I want as close to 6000 as possible and as much hole shot as possible do you guys recommend the titan4 17 or another 15?
Break down for the skimmer/trolls.
13 1/4x17p 3 blade solas 6000 rpms at 41 rpms
13x15p 4 blade solas amita4 6200 rpms at 33-34
Thanks
Thanks
