RPM
r j f
I have a 150 evunrude with a 14 1/2x19 on a 20ft WA,weight of boat with motor about 3200lbs I'm topping out at 4200 rpm. What's the best way to get up to about 5500 rpm. Any help would be great.<br />Thanks
JB
Re: RPM
Howdy, RJF.<br /><br />First, make sure that your engine is putting out all of its power. With the WOT rpm that low, I kinda doubt it.<br /><br />If that is okay, you need to investigate rigging. Is the Anti-ventilation plate even with or above the bottom? Is the boat well balanced, lifting the bow on accelleration and coming up smoothly onto plane?<br /><br />If all of the above is good, try a shorter pitch prop, though 19" seems in the right ballpark for that boat/engine package.<br /><br />I will move this to Evinrude Troubles, where it will get more attention.<br /><br />Good luck. :)
