Texasmark
- Joined
- Dec 20, 2005
- 14,795
I have discussed this topic more than once. I helped a guy with an OMC Sea Drive not too long ago that wouldn't respond to the throttle to get his boat up on plane....all he did was to allow the prop to spin up in the hole and the engine responded to the throttle. I suggested that he port his prop like the Merc. Laser II. As I recall that is what he did, either ported the one he had or bought one with ports. He left happy.
I have been running a 24P prop on my little tin lizzie with my 90 Merc. With the boat, hull, water conditions, altitude, weight and load, and the engine running properly, I could get up on plane pretty fast and move out. I could even leave the trim out, like it was set when I was running at WOT and get it to pop out of the hole as the engine would suck air (ventilate), unloading the prop, the engine would rev, the prop would bite, etc. etc. and in a flash you were up and away.
Today, in test driving the repairs to my engine I put a Ballistic 21P on the engine. In a straightaway this prop would let me run well over 6000 rpms, but I would immediately cut it back to around 5500 or a tad over.
So, just for fun, I would be idling along, trim still out in the WOT position (all the way out), give it some throttle to get up around 2500 and then smack it to the firewall. The boat would leap out of the water, would porpoise a couple of times while the engine at times would hit 7k ventilating but as soon as the prop caught (a second or two) the front half of the boat would literally leap out of the water; speed would pickup so fast that it would throw you against the seat. My sweetie just went nuts, hanging on to me.....YEAH!!!!!!! In no time, a couple of seconds, I was over 45 mph, loaded rpms well over 6k and at that I would cut the throttle back to get the rpms in range.
Point here is that a 2 stroke that isn't hindered by too much pitch for the work to be done can be an awesome power source.
So folks, prop them so that they can run where they love it and that is at the higher rpms. If you load them up, they bog down and die......but I'm not an expert, just commenting on the fun I have with my boat.
Surely a boo bird or two will jump in and poo poo on my thread. Well the lake is about 1200 acres, there were 3 boats on the lake, I avoided the other two who were fishing at the dam, we were both wearing our life vests, we were sitting on a vinyl covered and padded bench seat with back rest in normal bass boat fashion and the boat is BIA rated for 130 hp....I have a 90. Smile!
My 2c,
Mark
My 2c,
Mark
