Re: RPM''s for Mercruiser 1990 Alpha One 4.3L 175HP
Make sure your tach is right. 3400 is really low and I believe she would really struggle to get on plane if the tach is correct. There is a switch on most of them in the back for 4, 6 or 8 cyl. I would check that first.
You should get a new prop and keep the messed up one as a spare. You need a spare!! If the steering wheel is not shaking as it is, then you might get away without repairing the spare one, although that would be the right way to do it . . .
