Re: RPM's
With todays fuel and a top rpm of 5000 rpm with an average load is lugging the motor. You can leave it alone but be sure to decarbon every 50 hours as recommended. Perhaps more than every 50, maybe 35.
The closer the set up is to 5800, the cooler the combustion temps will be. The lower the conbustion temp is the less coking you'll have. Coking (sticky carbon-like substance) causes the rings to stick and eventually they could break.
Yes, the motor makes 70 hp at 5000, that's where the motor is rated at on a dyno by the NMMA. With today's fuel it'll live much longer set up closer to 5800.
