Two very different materials for two very different applications....
PRODUCT DESCRIPTION Sealant is a dark reddish brown, viscous liquid with a characteristic alcoholic odor. It is a slow drying, liquid that changes to a pliable, tacky film through solvent evaporation. It seals close fitting parts,machined surfaces and threaded connections in industrial,aircraft, marine and automotive applications.
PRODUCT BENEFITS•For close tolerance flanges•Slow drying•Flexible setting•Withstands pressures to 5000 psi
TYPICAL APPLICATIONS•Solid gasket dressing•Close fitting machined surfaces•Threaded connections•Aviation engines•Marine engines
PRODUCT DESCRIPTION Clear Silicone Adhesive Sealant is a general purpose, single component, room temperature vulcanizing (RTV) compound, designed for the sealing of mechanical assemblies. Upon curing from the exposure to moisture in the air, this non-sagging paste forms a tough, flexible, waterproof seal of silicone rubber, which resists aging, weathering and thermal cycling without hardening, shrinking or cracking.
PRODUCT BENEFITS•Easy application•Applied to horizontal or vertical surfaces•Superior adhesion and flexibility•Waterproofs•Insulates•Unaffected by vibration•Non-flammable•Non-toxic
