stuckinthehole
- Joined
- Aug 13, 2011
- 46
The top and bottom section of the hull have have started coming apart under the rub rail where they are normally connected. Looks as though the lip from the upper deck section is either broken or was never there....Any suggestions on how to repair?
I'm thinking about removing the rub rail and the replacing what appears to be a wooden spacer that sits between the two layers. Probably replace it with something other then wood that wont rot and then sealing the edge so no water can get through. I appreciate any suggestions. Thanks.
The boat is a just a 1999 Pacemaker Yachts Custom 19' Center console. I picked it up a few years ago off a buddy for cheap. He is the one that put the screws in it and tried sealing it with other materials as well. I am the third owner of this boat and I got it knowing I would have some work to do. Eventually I wouldn't mind stripping the whole thing down and rebuilding but now is not the time. What seems to have happened along the edge is the piece of wood in between the two layers has expanded and pushed the deck section up. I would like to get in to it and replace those wood pieces but I am not sure how get the old pieces out and new ones in without raising the deck off, which I don't have the equipment to do at the moment. The lower hull section comes up under the rub rail but the top deck section stops at the edge. After replacing the wood with something else I still need to find some way to seal that edge and then replace the rub rail. Thanks for any ideas you may have. I will be getting it into a shed next weekend where I can really start working on this.
