rubber bushings on flywheel coupler
finer things
my question is this, I have installed flywheel coupler on 1987 mercruiser 260 h.p when I took the coupler off the old engine I dont recall seeing any rubber bushings just the metal triangles at the bolt holes is this right, I used loc tite and torqued to 35 lb is this right
Don S
Re: rubber bushings on flywheel coupler
I am assuming that what you are calling a bushing may be the rubber bumpers (shown below) that Merc puts between the bolt holes to help support the coupler. I have seen them in a couple different shapes.
attachment.php
Ayuh,.... They help cut down any vibrations due to the lighter materials used for the task...
Ya don't see 'em on most full circumference couplers...
finer things
thanks I am assuming that since I didnt see any during dissassembly of old motor they were never there
