rubber dam, which way is up!
Archnawan
There is a rubber "dam" in the lower unit of my alpha one gen 2 that I (foolishly) removed for cleaning while replacing my water pump. Now I forget which way is up. One end is solid all the way across and one end has a raised portion at the rounded end. <br /><br />Any help?
cuzner
Re: rubber dam, which way is up!
You should be able to find a diagram at meruiserstuff . com<br /><br /> Jim
Archnawan
Cool, thanks for the pictures and the link to the manual. Didnt even know about that!<br /><br />I look at the upper unit and sure enough there is a little plastic dam, amde more sense then. <br /><br />Thanks for the help!
tommays
<br /><br />its the best picture i have hope it helps <br /><br /> http://www.boatfix.com/merc/Servmanl/14/14b3.pdf <br /><br />wait for this to load and go to page 78<br /><br />the beveled edges face the front and up if you have it upside down it wont be high enough to seal with the dam in the upper<br /><br />it drove me a littel crazy the first time to even in the service manual its not that clear<br /><br />tommays
