Rubber debris in cooling system
lord121645
I have found black rubber debris in the cooling system (foot) of my Yamaha 50 hp motor. It is not the impeller but must come from another source. I have cleaned it out 2 times but it continues to appear causing the engine to overheat. Any ideas of the source of these rubber particles?
Silvertip
Re: Rubber debris in cooling system
How do you know its not the impeller? Just because its still pumping water and you have a tell-tale stream doesn't mean the impeller hasn't lost a vane or two or is in the process of coming apart.
lord121645
lord121645
Thanks Silvertip. I know it is not the impeller because the first thing I did was to replace the old one which was worn. Any more ideas?
lord121645
Thanks Silvertip. I know it is not the impeller because the first thing I did was to replace the old worn one with a new one. Any more ideas?
badlar
After replacing the impeller on my F100, I ended up dropping the lower unit 3 more times before I got all of the rubber out.
lord121645
Thanks Badlar. That could be the problem. I have dropped the lower unit twice already. Maybe the third time is the charm.
