Rubber Substance Inside Hull?
AJ168
If you don't know, I have an aluminum 18' cc that leaks pretty badly. It was coated with epoxy, and there are several loose or missing rivets. <br /><br />I've finished cleaning off the epoxy from the hull, and am trying to find the size pop rivets I need. I tried cleaning out one of the holes of the missing rivets, and found a rubbet-like substance behind it. I don't know exactly what this stuff is, but it looks like a white rubber block inside the hull. Could it be some kind of flotation? Is it allright to just start putting pop rivets into place with this stuff there?<br /><br />The further I get with this project, the more and more I keep thinking that I should just tear the whole boat apart and start from scratch.
Re: Rubber Substance Inside Hull?
Probably...........<br />
IF it's Floatation Foam,......... Sure......<br /><br />You Are using Closed end Waterproof Pop rivets,..... Right,..??....<br />
The further I get with this project, the more and more I keep thinking that I should just tear the whole boat apart and start from scratch. <br />
Ayuh,........... That's Usually the Way it Works............... :rolleyes:
AJ168
It's not really foam though, it's like rubber. If it was just foam, I wouldn't even worry about it.
AJ168
I'll try. It's really hard to see because you only have a the hole of a missing rivet to view it. I think it's white but it definatley feels like rubber.
surlyjoe
its polysulfide caulking I bet aka:boatlife
