Don Hansen
- Joined
- Sep 17, 2007
- 230
I was using my 1970 4 hp to come up a creek when it slowed down to 3/4 speed. Maybe 30 seconds later it started to squeak and then make a heavy rubbing sound like someone using a coarse file on metal. Of course I shut it off. I was sure a coil had come loose.
There's a guy in my area who's noted for being good on older motors. He checked everything. The water pump, the coils, the gear box, and ran it for a half hour. He could not repeat the symptoms. He also said that the motor didn't appear to have over-heated.
I probably won't be able to take the motor out on a lake before my trip to Canada but I am going to run it in a barrel just to make sure. I'm just confused as to how the motor could make that rubbing sound and then have it go away like it never happened.
Has anyone here seen those symptoms?
DLH
DLH
