Rubbing On Gimbal Ring
roy c
I just purchased a complete fresh water gimbal housing and noticed what appears to have been rubbing on the lower starboard
​side of the gimbel ring. it runs along the bottom from forward to aft as if the out drive would have caused it from trimming in and out
I was wondering what could have caused this and if in anyone's opinion would it effect workability I looked ​on the outdrive there
was no sign at all of wear or chaffing. trying to attach a photo but n.g.
GA_Boater
Modified the thread title to be more descriptive than "
Click on Forum Help in the sig below and look at the Photo Posting Tutorial. The problem may be that you need 3 posts to remove the photo attachment restriction for new members, which you have met now.
BTW - :welcome: to the forum.
harleyman1975
Ensign
Not totally uncommon...have seen it on many sterndrives (of course that does not make it right)
Ayuh,.... Welcome Aboard,.... Pretty much normal,....
Prop thrust pushes the drive that way,....
Ya don't say what drive, but the Alpha, Gen.IIs use plastic wear plates in that location,....
roy c
Thanks for the response its a bravo 1 drive with a 454 engine/ I looked at the drive with no markings on the drive
​just wondering if the anode might have been placed on the forward end chaffing when drive was trimmed
roy c
I see a raised area on what I see on the web site I don't know if its anything other than part of the housing itself
​is it suppose to be a plastic pad or cushion? thanks
roy c
I finally got the picture to upload
roy c
you can what I mean with this photo I have know idea
what might of caused this again I looked over the outdrive
no sign of rubbing
achris
More fish than mountain goat
Check the transom housing and drive serial numbers. You may have a new drive in an older gimbal housing, hence no 'rub marks' on the drive.
Chris.......
