Need temporary help--manual on order--in meantime here is my problem. Have been fighting a missing cylinder ignition problem since vacation--during vacation had motor problem of which power pack was checked-it was ok, checked wiring from timer base. Voltage probes thru multiplug connector at timer base showed no voltage thru one wire. Part was not available at that time from this dealer(which was a distance from home). Arrived home, local dealer had one but no one to install it, carried out door later was installed by another dealer. Labor paid to install since I did see the technician locate no voltage thru previous test, felt confident that replacement would cure problem. WRONG, run today with same problem reapearing of missing cylinder. Can someone tell me the voltage thru the powerpack connectors to timer base, the proper way to check this and voltage to coils required. The manual I have ordered is on backorder. Holiday weekend and curious if timer base is laying down or if power pack is bad now, the same cylinder as before is without voltage. Have camera ready and can send pictures via e-mail to simplify communication. Thanks Dewly
