TheFormerlives
- Joined
- Feb 23, 2010
- 62
Just as the title implies, my 93 Evinrude 50hp overheated. Luckily this engine is still under warranty so its no cost to me. My question is what do you think went wrong? It was pumping a solid stream of water the entire time, there was a pop, my rpm's dropped, a puff of smoke out the exhaust and the buzzer went off. No weeds wrapped around prop or anything. Completely out of the blue.
This engine was just rebuilt about 2 months ago by a Marina, who said it overheated on the previous owner. So they bored over both cylinders and replaced pistons,rings, carbs etc.. (total rebuild). So could this have anything to do with the problem?
Was it something I did wrong? Fuel/oil mixture has been 50:1 and I run ethanol-free gas. The Marina said sometimes they "just overheat." And I'm not exactly sure I buy that. Is it likely it will happen again, or do these things sometimes just happen. Perhaps boring it over increased the horsepower a little bit too much for the cooling system? Thoughts, input, suggestions....???
