what does it take to runaway?<br />what serious damage occurs at high rpms?<br />pistons hit spark plugs,crank bearings gives?<br />the reason i ask is the shift rod is filed down at the neutral point.so if not careful it can start at WOT.<br />also while im here,a lot of oil/fuel/water<br />coming out of the little vents hole on the lower unit leaving a trail.<br />thanx in advance
