Part-time
- Joined
- Jul 5, 2011
- 536
My neighbours '84 evinrude 60 hp twin was just started for the first time this year.
Last year it had no isues.
It started fine but has an eratic miss... then it starts!
the miss goes away and the RPM's creep up (no tack to know exact numbers)
but higher than normal idle RPM.
then slows back down and has miss again.
During this time if you turn the key off engine will shut off.
After a little while the engine will rev up and down going a bit higher in rpm's
and then the RPM's will go wide open.
I mean this engine was just screaming!!!
Turn the key off, nothing, it just keeps reving out of control.
This is in neutral, linkage is in the position for idle, never moved, and the carbs are in the idle position as well.
What the heck is going on???
