I have a 1961 23 foot Chris Craft Sea Skiff that has been flawless for 10 years with a 283 flywheel forward motor cooled by a Sherwood double impeller pump (N10360GX) driven off the back of the generator. Since the boat doesn't have thermostats, it always runs around 110-115 degrees. Upon launching this Spring, it easily reached 130 degrees at 1200 RPM. It never ran this warm, so I changed both impellers. It had no affect, and still runs warmer than ever before.
Skupper is clean and water flow is present at all hoses I have pulled off when running. Drains in block have been
pulled and checked and there isn't any sand or mud behind them. Although I have water flow at all points, I don't
believe the flow or pressure is strong enough because I can easily stop flow with my hand. Flow was checked at 1000
RPM at the dock. I thought of a major rebuild kit for the pump but the boat only has 1100 hours on it, and the pump seems relatively simple in design. Housing is smooth with no stratches, and the bushing is good, and the scraft turns
smoothly. Boat has been used in fresh water only for the 10 years I've owned it. I would really appreciate any help
I can get....I really want to go boating.
Thanks
KeyKev......
Thanks
KeyKev......
