running a motor in a 55 gallon drum how long
rileychad
ive always wondered how long could you run a outboard motor in a 55 gallon drum because I know the circulation Is not as good and the water tends to get oiliey
any thoughts on this subject would be nice
thanks
cr
Chris1956
Re: running a motor in a 55 gallon drum how long
You can run it until the water gets hot. Of course, that will take a long time. Oil build up is not an issue. Circulation is fine if the barrel water level is above the waterpump impeller.
