barry light
- Joined
- May 2, 2009
- 19
I have always heard that when coming off the water for the day, to unplug fuel line to engine and continue to run engine until it quits, thus draining the carb bowls to keep fuel from sitting in bowls for extended period.
I acquired a 1992 Evindurde 115 hp ( crossflow 4 cylinder ) which has two, 2 barrel carbs. Each carb feeds two cylinders. Since the oil pump as been removed, I mix the oil with gas.
Is it okay to do this for this type engine? The reason I ask, that I am thinking if one of the carbs runs out of fuel before the other one does, the two cylinders would continue to keep the motor running, while the other two cylinders are not getting any lubrication because that carb is empty.
Is my scenario possible? If so, could this damage the engine? I just know with my experience with smaller one carb engines, that if you don't run the carbs out of fuel, and it sets awhile, it can gum up the jet in the bowl.
