Re: Running engine without the sterndrive in
kjdkjd said:
I attach the hose connection in a way that it leaks somewhat, so I don't try to send full municipal water pressure into the engine.
Depending on the type of raw water pump you have. I just drop the water pickup hose into a bucket of water and just keep the bucket full with the garden hose.
There is no problem running the engine with the drive out apart from the obvious things like pulling the drive shaft out, routing the exhaust so it doesn't fill the boat with carbon monoxide and KILL you, connecting the water pickup and ensuring the engine is properly supported at the rear.
