I have a 1986 Johnson 9.9 HP J8RCDE / B0105197. The engine ran hot (205 degree f)...no tell-tale...I cut it off. I pulled lower unit and found no key with impeller. Key was installed...lower unit back on...engine fired and ran...a few minutes later I had positive tell-tale water discharge. Now, a few minutes after this the water stream stopped...it appeared that steam / hot air was coming out....it ran hot again (200 degree f) I shut it off. I then removed the thermostat housing and thermostat. Fired it back up and exhaust gases (heavy) were coming out of thermostat .
Ant ideas of what's going on here.
Thanks
Thanks
